I’ve had metadata change for various movies after a couple of network outages. I had previously edited some of my movie files to obtain the correct metadata after a network outage the metadata reverts back to screen from the movie or an incorrect title. This happens across the two ATV’s I am running.
I find I have to re-edit the files to correct this.
This thread should shed some light on what is going on at the moment. I recommend you update to 6.4.2 if you haven’t already.
https://community.firecore.com/t/missing-or-incorrect-movie-artwork/19695/5
