Updated to 4.3 recently and for some reason the metadata for some of my TV Shows is not updating and just showing the grey folder.
Once I go into the folder it updates for some but others it remains the same.
Is there a way to manually fetch metadata for TV Shows? When I go to ‘Edit’, it shows some random titles that aren’t even close to the name of the folder and if I try type it in, it shows as ‘Nothing Found’. The shows are definately on TVdb.
