Hi
I’m trying not to use Metadata and for some reason it is still trying to fetch metadata everytime I try to access the video list. Metadata is disabled in the settings,
Any suggestion?
Mario
Hi
Any suggestion?
Mario
Same problem here. I have disabled metadata fetching; however, it seems like Media Player is still fetching data.
Maybe it’s just retrieving local file data but I don’t that’s the case. I guess, when I go home, i’ll try disconnecting the router from the modem and see what happens.
If it is still trying to fetch data I will report it as a bug.
