When Infuse scans the folder structure will it automatically give priority to the local metadata? Does the Embeded Metadata setting have any bearing on local metadata use?
I believe it should give priority to the local metadata over the downloaded\scanned metadata. So if you have custom artwork, it should give priority to that and not use artwork that could be downloaded…
