Hello,
I just rebuilt my library with tinymediamanager to get the right information locally in Infuse. I use DVD folders structure.
No matter how much I change the names of the images and the name of the nfo file, I can’t get any results in Infuse. No image and no metadata are used one my Apple TV 4k…
Thank you for the answer, indeed I had not thought of that! It seems to work, but it’s not practical at all. do you think there is a solution / option to force to use the metadata contained in the same folder?
