New user from yesterday - and am really liking infuse - having moved from the Plexverse etc. I decided to not use the plex server but rather NFS share, and everything is working very well on the whole. Playback is a dream. However - I have one issue. A few TV shows aren’t recognised by Infuse. Not a problem I thought - Long Press and try and edit the MetaData. However, when I long press on them the only options are ‘Playlist’ or ‘cancel’. I have around 400 different TV shows, and only a few miss - so my naming convention seems to be ok. One show that fails for example is ‘The 100’. The filename originally was The.100.s01e01. I tried to add the year - The.100.(2014).s01e01 - but still it appears as a playlist. I tried “The 100 s01e01” - no luck. I am at a loss as to how to fix this. There are a few others - and everyone that doesn’t seem to be picked up by Metadata seems to be a playlist that I cannot edit the Meta Data info. Any advice would be greatly appreciated.
