Media Player Stuck on Loading Movies streamed from NAS
I just added a second ATV2 to my home.  Both devices are running aTV Flash and streaming from a netgear NAS. The problem is the latest device is getting stuck on loading some movies (the loading message and the spinning disk just stays there for ever). This has never happened with the other device. Is there some network conflict occuring or could it be a faulty device?
It sounds like it may be a network issue, but if you’re able to send in a diagnostic report we’ll be able to provide more insight.
Thanks James. I will do that later tonight.
I think you are right about it being a network issue. The original ATV2 is now doing the same but with the same movie files. It played them before. :frowning:
