Does anybody have any idea what Media Player File Management actually allows me to do? I have toggled it and can't seem to see any extra options when enabled.
PATH: Media Player/Settings/General/File Management (choices are enabled or disabled)
It allows you to delete files from your library and your shares, the files are deleted from the hard disk. Hold down Select and you will see the new Delete option there.
