Media Player 0.3 Drill Down
Hi
I am using with a ReadyNAS Duo using AFP, mediaplayer find the share but won't drill down and even if i enter the folder path doesn't find any videos.
I also own a ReadyNAS DUO and for me it works fine. My media share has guest access. Let me know if you have specific questions about the setup.
Jeroen
I have a share called media with AFP access and guest access ticked but default access read only. In media player I enter 192.168.1.33/media and leave username and password blank. When I then go to the share I get a message no playable content. I am most confused.
Sorted, I had modified the share from before I enabled guest access. I deleted the share, ssh'd killall AppleTV. Then I recreated the share and all is working.
