Mark All Library or Folders as Read
I messed up with my libraries and had to recreate them from 0.
Now everything is marked as “non read”.
So far, I can only mark movie as read by selecting one by one…
From “Library” or “Directory”, the “… / Select” is not available.
Is there a way to select a bunch of videos and mark them “as read” ?
Thanks.
Marking items as watched in bulk isn’t available in the current version, but one thing you may consider is using Trakt.
Trakt allows you to sync watched history and progress between multiple devices and other apps. You can also mark items as watched on the Trakt website, and those changes will sync back to your account. Another nice thing is the watched history is tied to the title name, and not a specific filename or location, which means your watched history will be retained even if you move or rename items in the future.
A bit more info on how this works can be found here.
Ok, thank a lot. I’ll have a look at it.
Interestingily marking a whole season of a TV show as read is possible on the AppleTV (by long-pressing on it) but not on an iOS device.
