I know there's a common problem with the Library View that "now indexes all your media (even if stored on multiple devices) and automatically organize movies, TV shows and music into easy to use categories such as: genre, release date, star rating, age rating and others." in that it makes mistakes and incorrectly categorises files without letting you fix it manually?
I believe that I found the pertinent file ("com.firecore.media.meta.db") in /private/var/mobile/Library/Preferences/Media and am now trying to work out how to make the fix... using the Sqlite Database Browser, I can't find the table/record/field that identifies a file as a "Movie" or as "Other". I'm tempted to just put the IMDB listing number in the column but doubt that would work...
Any thoughts, pros?
Thanks!
Please let me know if you ever figure this out - I’m definitely interest in this!! I primarily use Infuse Pro 5 now on multiple devices, but I still use Infuse 2 on two 2nd generation Apple TVs.
Thanks!
