Maintenance
I keep seeing mention to go into “Maintenance” and turn off auto updates. I am really new this, just got the ATV and software, but I do not see Maint. anywhere. Any help to where I can look? Running OS version 2.2 on the AppleTV and the most current version of the ATV
Thanks!!
What menus do you see on the AppleTV?
I too have this issue - from the main apple tv menu screen I see the following options:
XBMC/Boxee
Movies
Music
TV Shows
Podcasts
Youtube
Photos
DVD
Internet
Jaman
Settings
I do not see a “Maintenance” option anywhere and am trying to install flash. would this be easiest to fix with the upcoming release?
I ended up having to do a restore and reload the Software. When you load ATV Flash the first time, loading Maint is not a checked option, it is an optional install, so more than likely that is your issue as well. Not sure if you have to re-install like I did or if you can just upgrade it though
