Maintenance update not working
It says there is a Maintenace update. So I update and reboot but it still says update there.
Are you wired or WiFi? Same thing happened to me. Maintenance Update never switched to Installed. Also, Infuse wouldn’t install. Switched to wired connection and, BINGO, both installed fine although I still can’t log in to Hulu or stream HBOgo. Wish I could fix those. IMHO it has to do with the latest Update.
Mine is wired, but behaves this way, as well.
