Maintenance update issues
Anyone suggest how I fix the following issue when trying to update remote hd and maintenance
E:dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
New to this so not sure how to remedy, any help really appreciated.
I’m getting exactly the same as above, I’ve ssh In and ran the above it didn’t fix it
Also getting the same error! ssh many times but does not fix also nothing will update in the nito options
Can you try re-running the aTV Flash (black) installer?
Were you previously trying to remove XBMC by chance?
I managed to fix this
Hard reboot by removing the power
Ssh and run the suggested commands
Restart lowetide
Bingo updates work
Just updated to beta 7 by resetting and reloading
Seas0npass then the beta and bingo all’s good again
Cheers for all the replies.
