Maintenance menu
Hello,
I'd like to learn how to re-enable Maintenance menu.  I have Overflow installed and am running the lastest version of aTV Flash for Black.
Thank you,
T
Was Maintenance hidden or moved by Overflow? If so, you should be able to revert the settings through the Overflow menu.
I solved the problem by restoring my atv2 to its original software via iTunes.  And then re-installing atv2 Flash Black.  This brought back my Maintenance menu.  If there is a easier way, I am unaware of it.
Hope this helps someone else.
T
It was hidden.
Thank you,
T
