Maintenance Menu?
I’ve jailbroken my Apple TV 2 and installed ATV Flash.  I followed the tethered boot process, and on my Apple TV homescreen, the Settings App now is the Firecore icon, so I know something has happened, however when I go into it, I can’t find the maintenance menu.  Actually everything else looks exactly the same as before except the Firecore icon.
Can someone tell me where to find the maintenance menu?
thanks
figured it out!  Ignore me!
Hi Marc,
any hints on what you found, i have the same issue.
You do not get the Maintenance menu simply by Jailbreaking. That menu appears when ATV Flash is installed.
try to do the jailbreak another time :wink:
