Low speed when streaming from Onedrive on Mac
I’m currently using the latest version of infuse on MacOS Bigsur. The speed is extremely slow and has a strange changing pattern as if it’s limited, no matter if it is on WiFi or ethernet. But on iPhone or ATV in the same network, there is no such problem. Why this happens and is there anything I can do?
Is this consistent for you, or does the speed fluctuate?
Infuse will stream as quickly as it can from all cloud servers, but there are a number of factors which can affect this (network, ISP, node location/congestion, etc…).
Do you have any other shares set up in Infuse? Are you getting normal speeds from those?
