im getting a loud click when a movie starts , playind a vob, using Media player,
AVT flash 0.7
AVT flash 0.7
Disable AC3 Passthrough
Cheers, that was an easy fix ![]()
Essentially what’s happening is that when playback begins/resumes the AppleTV will switch from PCM (analog) to AC3/DTS (digital) sound. Some receivers will take a moment to recognize the switch, and will incorrectly process the digital sound as analog. This results in the split second of static you hear.
We’re planning to address this in a future version.
Yes, and i think this is the reason, why AC3 Passthrough doesn’t work correctly. I posted in another thread, that AC3 passthrough works for me when i disable the “click” sound if you press the remote.
Then the Receiver doesn’t get this PCM - AC3 switch because there is no sound before the film starts. But DTS works fine all the time…
Here my post:
http://forum.firecore.com/topic/5011?page=2
Regards Chris
P.S. I’m using Media Player 0.7 on iOS 4.2.2 jailbreaked with Seas0nPass
Interesting. Maybe we can kill two birds with one stone. ![]()
I’ll keep my fingers crossed!
I just want to update, that in Beta7 AC3 still doesn’t work correctly, when the “Click” Sound is enabled…
I’m disappointed…
