It happened to me only with ver 5.1 using snowbreez ifaith
After installing xbmc from the Nito. Xbmc logo is black. But still there. Xbmc work fine and add-ons work perfect with no issue. The Only complaint is that you see xbmc logo black. No logo. Any help will be appreciated thx
look for a post by showfoto in it on the last page it shows you how to add it back
I rejailbreak 5.2 & reinstall it from the command Line & not from Nito installer
http://wiki.xbmc.org/index.php?title=HOW-TO:Install_XBMC_on_Apple_TV_2#ATV_5.x
Thx all for your help. I did check showfoto. And I fixed the problem. Thx if anyone need or interested on how. I put the info here
I need to know how to do it? I take it is done with putty. Can you please give me a step by step guide because I have never had to SSH before… Any help would be appreciated.
1.power up your jailbroken atv2 until led is stable(not blinking) & connect atv2 into your router via ethernet cable.
2.Install nito installer, after installed open nito installer & it will automatically detect its ip address . Please Note the ip address detected. From here you can actually click instal xbmc but i think its better from the command line using putty.
- open up putty , in the host name field type the ip address from No 2. port 22
4. http://imho.nu/iMHo/jailbreak/putty/ <=== nice guide
- Next http://wiki.xbmc.org/index.php?title=HOW-TO:Install_XBMC_on_Apple_TV_2#ATV_5.x <=== for the xbmc part
Use winscp. Use your ip.
User root.
Pass alpine
This is the path you fallow :
Var/mobile/library/caches/AppleTV/MainMenu
Now add extension with png. To everything or just the one that says xbmc Close the application
Reboot Apple TV. And u get your logo
works a treat, my logo has been missing for months and now its back…cheers!
Now add the extenstion png. How do I do that?
Do like you wanna rename keep the whole thing and add .the extentoon
Awesome…thank you!!
