Lost Library
I recently noted that my media player would not locate new files I put into the shared folders. They were visible through the file section (and loaded metadata) but not in the library. I tried removing the share then reloading the whole library… Now the whole library is gone!!! Again, all files are visible through the files area but not the library.
Can anyone help?
That seems to be similar to the behavior I’m experiencing, so far no practical answer from firecore…
