losing NAS
Hi, I keep losing my NAS. Infuse will find it and connect and everything works fine but when I try a day later it shows my NAS but there is no connection, only the spinning circle!! I have to delete the NAS and then it will reappear and I can connect again. Ane suggestion what I might do?
I posted twice I see, could You remove the double please?
Was the NAS setup manually, or did you use one of the pre-identified shares found by Infuse?
The only thing I can think of if it was setup manually and the IP address (instead of DNS name) was used that may cause an issue, as IP addresses will often times change when devices are reconnected to the network.
