Long-press context menu while browsing libraries in Direct Mode
(Plex direct mode) The long-press context menu only shows up when the item is located on the Infuse home screen. Holding down the center button on ATV or long pressing an item under “favorites” does nothing (ex. the entire th-show library from a Plex server). Same if you select “show all” from a row on the home screen. It would be nice that the contect menu is active anywhere and not only items on the homescreen.
A post was merged into an existing topic: Context menu for Direct Mode
