log files attached - Jailbreak issue -Please help :)
This is the sort of messages I'm getting after 3 attemps.
Running 5.3 was running 6.1.1
Cuts me off right from the start.
DateTime: 26/05/2014 20:12:03 Message: Application start
DateTime: 26/05/2014 20:12:03 Message: Seas0nPass 0.9.5.15470
DateTime: 26/05/2014 20:12:03 Message: clean up
DateTime: 26/05/2014 20:12:04 Message: Started iTunes exe search
DateTime: 26/05/2014 20:12:04 Message: Using registry view Registry64
DateTime: 26/05/2014 20:12:04 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 26/05/2014 20:12:04 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 26/05/2014 20:12:04 Message: Found 36 subKeyNames
DateTime: 26/05/2014 20:12:04 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{96B53CA8-5ABB-49D8-96F1-F6C0D73A76C6}
DateTime: 26/05/2014 20:12:04 Message: Path to iTunes is C:\Program Files (x86)\iTunes\iTunes.exe
DateTime: 26/05/2014 20:12:04 Message: Installed iTunes version: "11.1.4.62". IsCompatible? True
DateTime: 26/05/2014 20:12:05 Message: Started version check
DateTime: 26/05/2014 20:12:06 Message: Seas0nPass version is OK
DateTime: 26/05/2014 20:12:07 Message: ECID process starting
DateTime: 26/05/2014 20:12:07 Message: Output received: check_context(00000000)
DateTime: 26/05/2014 20:12:07 Message: Output received: ECID: 3962124942605
DateTime: 26/05/2014 20:12:07 Message: Output received: check_context passed
DateTime: 26/05/2014 20:12:07 Message: Checking available blobs on Cydia servers for ECID = 3962124942605
Exception occured
!!! Unhandled Exception caught in AppDomain.CurrentDomain.UnhandledException !!!
Exception occured
DateTime: 26/05/2014 20:16:42 Message: Application start
DateTime: 26/05/2014 20:16:42 Message: Seas0nPass 0.9.5.15470
DateTime: 26/05/2014 20:16:42 Message: clean up
DateTime: 26/05/2014 20:16:42 Message: Started iTunes exe search
DateTime: 26/05/2014 20:16:42 Message: Using registry view Registry64
DateTime: 26/05/2014 20:16:42 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 26/05/2014 20:16:42 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 26/05/2014 20:16:42 Message: Found 36 subKeyNames
DateTime: 26/05/2014 20:16:42 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1CF5754A-545B-4360-BFDE-2847BC728DFC}
DateTime: 26/05/2014 20:16:42 Message: Path to iTunes is C:\Program Files (x86)\iTunes\iTunes.exe
DateTime: 26/05/2014 20:16:42 Message: Installed iTunes version: "11.2.0.115". IsCompatible? True
DateTime: 26/05/2014 20:16:44 Message: Started version check
DateTime: 26/05/2014 20:16:44 Message: Seas0nPass version is OK
DateTime: 26/05/2014 20:16:45 Message: ECID process starting
DateTime: 26/05/2014 20:16:45 Message: Output received: ECID: 3962124942605
DateTime: 26/05/2014 20:16:45 Message: Output received: check_context(00000000)
DateTime: 26/05/2014 20:16:45 Message: Output received: check_context passed
DateTime: 26/05/2014 20:16:45 Message: Checking available blobs on Cydia servers for ECID = 3962124942605
Exception occured
Exception occured
DateTime: 26/05/2014 20:18:38 Message: Application start
DateTime: 26/05/2014 20:18:38 Message: Seas0nPass 0.9.5.15470
DateTime: 26/05/2014 20:18:38 Message: clean up
DateTime: 26/05/2014 20:18:39 Message: Started iTunes exe search
DateTime: 26/05/2014 20:18:39 Message: Using registry view Registry64
DateTime: 26/05/2014 20:18:39 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 26/05/2014 20:18:39 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 26/05/2014 20:18:39 Message: Found 36 subKeyNames
DateTime: 26/05/2014 20:18:39 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1CF5754A-545B-4360-BFDE-2847BC728DFC}
DateTime: 26/05/2014 20:18:39 Message: Path to iTunes is C:\Program Files (x86)\iTunes\iTunes.exe
DateTime: 26/05/2014 20:18:39 Message: Installed iTunes version: "11.2.0.115". IsCompatible? True
DateTime: 26/05/2014 20:18:41 Message: Started version check
DateTime: 26/05/2014 20:18:41 Message: Seas0nPass version is OK
DateTime: 26/05/2014 20:19:00 Message: ECID process starting
DateTime: 26/05/2014 20:19:00 Message: Output received: check_context(00000000)
DateTime: 26/05/2014 20:19:00 Message: Output received: check_context passed
DateTime: 26/05/2014 20:19:00 Message: Output received: ECID: 3962124942605
DateTime: 26/05/2014 20:19:00 Message: Checking available blobs on Cydia servers for ECID = 3962124942605
Exception occured
Exception occured
does anyone have any ideas?
Seems strange.
I'm in a similar boat. My logs below:
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleRGBOUT verify_swap failed
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleM2ScalerCSCDriver: Added framebuffer device: AppleRGBOUT  id: 8020f000
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSamsungSerial: Identified Serial Port on ARM Device=uart4 at 0x82900000(0x8cf09000)
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSamsungSerial: Identified Serial Port on ARM Device=uart3 at 0x82800000(0x8cf0c000)
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleD1815PMUPowerSource: AppleUSBCableDetect 1
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleD1815PMUPowerSource: AppleUSBCableType USBHost
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSynopsysOTGDevice::init : Logging Buffer Length = 4K
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSynopsysOTGDevice::start : buffer-options 0x00000400
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSynopsysOTGDevice::start : object is 0x8033dc00, registers at 0x8cfac000, 0x86100000 physical
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSynopsysOTGDevice::findMaxEndpoints: in EPs: 7, out EPs: 7, max_endpoint: 8, num_endpoints: 14
DateTime: 26/05/2014 21:08:46 Message: Output received: AppleSynopsysOTGDevice::handleUSBCableConnect cable connected, but don't have device configuration yet
DateTime: 26/05/2014 21:08:46 Message: Output received: display-scale = 1
DateTime: 26/05/2014 21:08:46 Message: Output received: display-rotation = 0
DateTime: 26/05/2014 21:08:46 Message: Output received: using DisplayPort as primary display
DateTime: 26/05/2014 21:08:46 Message: Output received: attempting to power on display port
DateTime: 26/05/2014 21:08:46 Message: Output received: found AppleRGBOUT framebuffer
DateTime: 26/05/2014 21:08:46 Message: Output received: starting display hot plug thread
DateTime: 26/05/2014 21:08:46 Message: Output received: waiting for matching IOKit service: <CFBasicHash 0x1ed0d5f0 [0x2bf100]>{type = mutable dict, count = 1,
DateTime: 26/05/2014 21:08:46 Message: Output received: entries =>
DateTime: 26/05/2014 21:08:46 Message: Output received: 2 : <CFString 0x4076a4 [0x2bf100]>{contents = "IOProviderClass"} = <CFString 0x1ed0d620 [0x2bf100]>{contents = "AppleUSBDeviceMux"}
DateTime: 26/05/2014 21:08:46 Message: Output received: }
DateTime: 26/05/2014 21:08:46 Message: Output received: read new style signature 0x43313131 (line:389)
DateTime: 26/05/2014 21:08:46 Message: Output received: [FTL:MSG] VSVFL Register  [OK]
Exception occured
Application:       Seas0nPass
Version:           0.9.5.15470
Date:              26/05/2014 21:08:46
Computer name:     DENISE-LAPTOP
User name:         Denise
OS:                Microsoft Windows NT 6.1.7601 Service Pack 1
Culture:           en-US
Resolution:        {Width=1280, Height=800}
App up time:       04:07:12.2163543
Exception classes:
   System.FormatException
Exception messages:
   Input string was not in a correct format.
Stack Traces:
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
   at Seas0nPass.Models.DeviceRestoreModel.HandleOutputData(String data)
   at Seas0nPass.Models.DeviceRestoreModel.<RunDeviceRestore>b__0(Object sender, DataReceivedEventArgs e)
   at System.Diagnostics.Process.OutputReadNotifyUser(String data)
   at System.Diagnostics.AsyncStreamReader.FlushMessageQueue()
   at System.Diagnostics.AsyncStreamReader.GetLinesFromStringBuilder()
   at System.Diagnostics.AsyncStreamReader.ReadBuffer(IAsyncResult ar)
   at System.IO.Stream.ReadWriteTask.InvokeAsyncCallback(Object completedTask)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.IO.Stream.ReadWriteTask.System.Threading.Tasks.ITaskCompletionAction.Invoke(Task completingTask)
   at System.Threading.Tasks.Task.FinishContinuations()
   at System.Threading.Tasks.Task.FinishStageThree()
   at System.Threading.Tasks.Task.FinishStageTwo()
   at System.Threading.Tasks.Task.Finish(Boolean bUserDelegateExecuted)
   at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot)
   at System.Threading.Tasks.Task.ExecuteEntry(Boolean bPreventDoubleExecution)
   at System.Threading.Tasks.Task.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
loki2461, try to run seasonpass in XP compatability mode. If it doesn't help then I have nothing else for you.
After failing to jailbreak a couple times, i went back to iTunes and to do a restore on it, but that failed. I noticed i was getting error codes with the USB hub (motherboard). I then switched computers and tried to do an iTunes restore, but the other computer wouldn't recognize the appleTV as it was halfway into a downgrade jailbreak. I then swapped out cables and used differnet ports on the 1st computer. I was able to do a restore through iTunes.
I switched computers, switched cords out, and ran in compatability mode. Everything went very smooth. Note that i needed to have the power cord plugged in at all time. This is contrary to the wiki and other notes. Thanks for your help.
Thanks for The feeback. I have sent mine away...whats your model number?
