I am using a MacBook Pro (M1 Pro) and have encountered an issue while playing 4K HDR videos on my built-in display.
When I play a remuxed 4K HDR video from Blu-ray in Infuse, both HDR and local dimming work perfectly. However, when I encode a 4K HDR video using HandBrake (settings: H.265 10bit (x265), average bitrate 16000kbps) and then play it in Infuse, the colors appear to support HDR, but local dimming does not function. (I also tested this on an iPad Pro 12.9 (5th), and the issue was the same.)
Interestingly, the same file plays correctly with both HDR and local dimming in IINA. This makes me think there might be a specific issue with Infuse.
I would appreciate any guidance or solutions regarding this matter.
Additionally, here is the Mediainfo for the encoded video:
General
Unique ID : 239274776565457940481874264048170515270 (0xB402A54D686054A2B03855F6767D3B46)
Complete name : Arrival.2016.mkv
Format : Matroska
Format version : Version 4
File size : 16.9 GiB
Duration : 1 h 56 min
Overall bit rate mode : Variable
Overall bit rate : 20.8 Mb/s
Movie name : Arrival (2016)
Encoded date : UTC 2024-09-29 20:32:27
Writing application : HandBrake 1.8.2 2024081000
Writing library : Lavf61.1.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 1 606 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Writing library : x265 3.6+1-aa7f602f7:[Windows][GCC 13.2.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1606 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / temporal-layers=0 / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=1 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / rskip-edge-threshold=0.050000 / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.75 / psy-rdoq=4.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=16000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50) / cll=9977,240 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass / no-mcstf / no-sbrc
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 9977
MaxCLL_Original : 9977 cd/m2
Maximum Frame-Average Light Level : 240
MaxFALL_Original : 240 cd/m2
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.23 GiB (7%)
Title : Surround 5.1
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 50 min
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Duration : 1 h 31 min
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Language : English
Default : No
Forced : No
Text #4
Format : PGS
Language : English
Default : No
Forced : No
Text #5
Format : PGS
Language : Arabic
Default : No
Forced : No
Text #6
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #7
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #8
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #9
Format : PGS
Language : Czech
Default : No
Forced : No
Text #10
Format : PGS
Language : Czech
Default : No
Forced : No
Text #11
Format : PGS
Language : Danish
Default : No
Forced : No
Text #12
Format : PGS
Language : Dutch
Default : No
Forced : No
Text #13
Format : PGS
Language : Estonian
Default : No
Forced : No
Text #14
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #15
Format : PGS
Language : French
Default : No
Forced : No
Text #16
Format : PGS
Language : French
Default : No
Forced : No
Text #17
Format : PGS
Language : German
Default : No
Forced : No
Text #18
Format : PGS
Language : German
Default : No
Forced : No
Text #19
Format : PGS
Language : Hungarian
Default : No
Forced : No
Text #20
Format : PGS
Duration : 1 h 37 min
Default : No
Forced : No
Text #21
Format : PGS
Language : Icelandic
Default : No
Forced : No
Text #22
Format : PGS
Language : Italian
Default : No
Forced : No
Text #23
Format : PGS
Language : Italian
Default : No
Forced : No
Text #24
Format : PGS
Language : Korean
Default : No
Forced : No
Text #25
Format : PGS
Language : Latvian
Default : No
Forced : No
Text #26
Format : PGS
Language : Lithuanian
Default : No
Forced : No
Text #27
Format : PGS
Language : Norwegian
Default : No
Forced : No
Text #28
Format : PGS
Language : Polish
Default : No
Forced : No
Text #29
Format : PGS
Language : Portuguese
Default : No
Forced : No
Text #30
Format : PGS
Default : No
Forced : No
Text #31
Format : PGS
Default : No
Forced : No
Text #32
Format : PGS
Language : Romanian
Default : No
Forced : No
Text #33
Format : PGS
Language : Russian
Default : No
Forced : No
Text #34
Format : PGS
Language : Russian
Default : No
Forced : No
Text #35
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #36
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #37
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #38
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #39
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #40
Format : PGS
Language : Thai
Default : No
Forced : No
Text #41
Format : PGS
Language : Thai
Default : No
Forced : No
Text #42
Format : PGS
Language : Turkish
Default : No
Forced : No
Menu
00:00:00.000 : :Chapter 1
00:09:54.511 : :Chapter 2
00:17:38.140 : :Chapter 3
00:24:31.553 : :Chapter 4
00:33:58.620 : :Chapter 5
00:43:50.962 : :Chapter 6
00:52:30.689 : :Chapter 7
00:57:38.789 : :Chapter 8
01:03:10.704 : :Chapter 9
01:09:33.461 : :Chapter 10
01:17:23.681 : :Chapter 11
01:25:26.204 : :Chapter 12
01:35:41.653 : :Chapter 13
01:41:00.346 : :Chapter 14
01:43:43.384 : :Chapter 15
01:45:37.998 : :Chapter 16
P.S. I tested only with one video file, so I’m not sure if this issue occurs with just that file or with all videos.
