Local artwork for downloaded folders not showing anymore
I updated to Infuse 8.1 yesterday and from then local artwork for downloaded folders that was displayed before the update are now gone.
Have you experienced the same?
It happened to me too
Hello, I am writing to inform about a problem I am having with Infuse on iOS with my iPhone. I have been using Infuse for months and never had problems with folder covers added directly (without using Plex or others) in which I add the cover by saving a file in the folder I want with the name “folder” in jpg/png format and with a size of 1000x1500px, however recently I have had a problem in which none of these covers appear except for movie covers that are from the app database. I have tried deleting the application twice without any solution, the only way I have seen the cover appear is if I add the folder from an external folder and not saving it from the Infuse folder or when I put my folders in the application as a list, although these two are solutions I prefer to use Infuse the way I used to before without using Plex or adding the folders manually, simply having these folders in the Infuse folder, so I was wondering if there’s any way to fix this, thanks for reading.
A fix for this will be included in Infuse 8.1.1 which was submitted to Apple today.
Thanks for your patience. :slightly_smiling_face:
This has been resolved in today’s 8.1.1 update.
Should the artwork reappear automatically, or do we need to re-upload the artwork into the folder?
It should just work after installing the 8.1.1 update. No need remove and re-add the artwork.
It worked, thanks @james !
