Ok…here’s an interesting little bug…
If I add all items from my network shared external HDD to the library and try accessing any of these movies (avi) through My Files / Library I get a “Playback error, an error occurred loading this content”
However…if I access the movies through My Files / Remote / “Shared HDD” they all play as it should…!!!
Can someone please explain…??!
/Fred
[quote="figgehedberg"]
Ok....here's an interesting little bug..... If I add all items from my network shared external HDD to the library and try accessing any of these movies (avi) through My Files / Library I get a "Playback error, an error occurred loading this content" However....if I access the movies through My Files / Remote / "Shared HDD" they all play as it should.......!!!!! Can someone please explain..??! /Fred
[/quote]
I'm having exactly the same issue. SMB share, with username and password. Plays fine via "Remote" but any file accessedvia the Library fails with the same error. Did you ever find any resolution for this?
No unfortunately not....ended up using Plex after a while.
