Lighter Dolby vision playback
Since infuse starting playing these formats everything has been extremely dark.
I’m on an iPhone 13 Pro Max and usually I have trouble seeing anything if I try to watch something on hdr10/Dolby vision as everything is way way too dark.
Most tvs can adjust the gamma (I don’t know the correct term) of the Dolby vision stream so one is able to actually see anything at all.
I play lots of shows when commuting on the train and I just need to use 1080p files as hdr/dv files are way too dark on infuse.
I know the “correct way” to watch a dv file is using the full dr of the screen, but not seeing almost anything when playing in daylight is not desirable.
Can you actually implement something like this? It’s really, and I mean REALLY frustrating.
