Library - possible to exclude a share?
Is it possible to exclude a share (or a folder) from being indexed by the Library function? I have a share with duplicate movies and TV shows (some with different file names) that I don’t want to be picked up in the library.
Thanks.
Yes, you can pick and choose which favorites are included in the Library. This can be done through the Settings > Library menu.
For subfolders within an existing Favorite, you will want to create a new Favorite for that folder (via Settings > Shares > Share Name > Add Favorite) and then uncheck it from the Settings > Library menu. Additionally, you can hide this Favorite from the home screen by long-pressing on it.
Most excellent, thanks James!
