Library not showing all seasons
When I go under Library, I have Movies, Tv Shows, and Other (not sure what other is, not a folder I made).
Under Tv Shows, All TV shows, I only see 1 season/1 episode of a show. Not everything is listed. However, if I go under my TV Shows Favorite, I can see all my seasons/episodes. Any idea why this is? I have refreshed, still nothing
Are the missing shows listed under ‘Other’ by chance? If so, you may try selecting the ‘Edit’ option that appears under one of them to see if you can choose the correct title.
You may also check to ensure you’re using one of the currently supported naming styles for TV shows.
