In Settings > Library > Plex Server it says “Library mode disabled” and it’s greyed out.
On the Home screen there Only “Watching” section, “Favourites” section (Plex server), and "Watchlist - Plex server section, and “Recently added in movies” plex server section despite everything in the Home Screen settings enabled.
How do I get Infuse displaying allpinned items (sections) again?
This is what I’m talking about:
james
August 2, 2024, 4:49pm
3
When using Plex you can switch between Library Mode and Direct Mode.
Library Mode would allow you to make use of the categories and lists generated by Infuse. In Direct Mode you have access to the lists made by Plex.
Some more info on the differences and how to switch can be found here.
Infuse 7.7 has landed and includes our all-new Direct Mode feature for Emby, Jellyfin, and Plex. Direct Mode for Emby, Jellyfin, and Plex Direct Mode is a new connection option in Infuse which provides a more seamless experience when using popular...
Ok, thank you. That worked.
But I have no metadata for plex server movies.
james
August 2, 2024, 7:55pm
5
This is a known issue when using iOS 18 betas and you can follow this thread for updates.
I’m testing Infuse and in my:
Iphone 15 pro max
Ipad Pro M4-
I lost all metadata from my library (movies, tvshows, covers, etc)
I tried to delete all metadata to recreate it again but it didn’t fix it ?
Could it be i am at IOS/IPADOS 18 beta 3 in this devices ?
But everything works fine with my metadata in my:
Apple TV 4K 2022 and is on TVOS 18 beta 3
Thanks,
system
Closed
September 1, 2024, 7:55pm
6
