I think that the “Go to Show” and “Go to Season” options would be immensely helpful in navigating media. There were two other suggestions opened several years ago and were closed without comment or resolution. Any plans for that in the future?
Where would these options be listed?
Go to which show? Which season?
In the long press menu when hovering. It would take you to the show that you were hovering and/or the specific season of that show. Pretty much how it works in Plex
Don’t you go right to the show when you just click the poster?
Not from “up next” you don’t, which is just bizarre
@jmquik
It’s marked as an upcoming feature…at least for “go to season”
Hopefully “go to show” will also be an option.
