Library mode
Hi, I love this app and I really want to know if you have a really large library you can never use library mode ?
Define really large. Also are you connected to media servers like Plex?
Yes, I’m connected to plex and library size 20k movies 16k shows
You can try both and see which fits your needs better. Try it with the Library enabled and once the first scan completes then you’ll be able to see how it functions compared to direct mode.
You’re not locked into either solely based on library size.
Okay,do I need the application to be on throughout ? Or it can be updated in the background ?
