I have the latest pro version on my applrtv (5.5.3)
I have 3 shared folders connected from my synology NAS using NFS. TV Shows, Movies and Kids. I can open each of the favourites to browse inside them, although takes a long time to open the movie folder as it contains 100 of movies.
I am able to view a play from all of these okay. When I go to the library I can then see all the movie and tv shows grouped. Then every now and again the library reports empty? Nothing to show.
I then navigate back to the Movie and Kids favourite folders and all the movies come back and they re appear in the library. The TV shows however do not come back unless I look inside each tv show individually. Very slow and annoying process that I have now had to do several times.
I have sync turned off in case it is getting confused with the version running on my pad
Why does the library keep reporting empty?
Thanks.
