Library filter missing on Mac
I noticed that on the Apple TV I can filter the Library by Resolution (4K, HD, SDR etc.). This filter is sadly missing on the Mac. Would be nice to add that to the Mac OS version.
Hi. You can put shortcuts on the home screen, (I have one for 4K movies), using the home screen customization button (top right when on the home screen)
If the Mac top bar does not display (which might happen with Sequoia), go to a movie of TV show detail page, then back to the home screen.
Thanks! That way I found the option and your suggestion is indeed a good workaround to the issue. I still hope that this gets fixed with one of the next updates, so that the filter starts showing under library again.
