Length is not showing up for some movies (a lot of movies actually - despite the length is there on TMDb). It doesn’t work when I choose edit metadata and loads the metadata again either. Maybe a bug? Is there a solution?
I’m pretty sure that Infuse does not get the length from the metadata sources such as tmdb for files, it looks at your actual file and determines it from there.
It does take a while for Infuse to determine length so it may not appear immediately after adding the files. I’ve found that if I highlight the file without length Infuse will figure it out faster and display the length when it shows the rest of the metadata for that file but it may take some time to do it for all files.
