I am posting the following log in hopes that someone can tell me how to resolve this issue. I have done this installation several times and has resulted in the same. I updated and still no joy. I have no issues with changing file or folder permissions if that is what is required. It says successful at the end but tons of failures loading Kexts and no USB disk is mountable. NitoTV was updated today.
2012-04-02 16:15:16.064 nitoHelper[335] Root filesystem already writable
2012-04-02 16:15:20.512 nitoHelper[335] kextloader already installed!
2012-04-02 16:15:21.272 nitoHelper[335] CFLog (0):
CFPropertyListCreateFromXMLData(): plist parse failed; the data is not proper UTF-8. The file name for this data could be:
/Users/frontrow/Library/Cookies/Cookies.plist
The parser will retry as in 10.2, but the problem should be corrected in the plist.
2012-04-02 16:15:21.274 nitoHelper[335] mach_kernel.prelink already patched or unrecognized
2012-04-02 16:15:21.720 nitoHelper[335] bins installed successfully!
2012-04-02 16:15:56.994 nitoHelper[335] Bluetooth.prefPane install failure
2012-04-02 16:15:57.009 nitoHelper[335] Bluetooth.menu install failure
2012-04-02 16:15:57.025 nitoHelper[335] rc.local addition success
kextload: /System/Library/Extensions/AppleAltiVecDVDDriver.bundle/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AppleAltiVecDVDDriver.bundle/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /-v: no such bundle file exists
can’t add kernel extension -v (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/AppleHDA.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AppleHDA.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/AppleSMBIOS.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AppleSMBIOS.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/AppleTCOWatchdog.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AppleTCOWatchdog.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/AppleVADriver.bundle/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AppleVADriver.bundle/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/AppleVADriver.bundle.og/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AppleVADriver.bundle.og/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/AudioIPCDriver.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/AudioIPCDriver.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/cddafs.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/cddafs.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/Dont: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/Dont (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /Steal: no such bundle file exists
can’t add kernel extension Steal (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /Mac: no such bundle file exists
can’t add kernel extension Mac (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /OS: no such bundle file exists
can’t add kernel extension OS (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /X.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension X.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/GeForceFXGLDriver.bundle/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/GeForceFXGLDriver.bundle/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/GeForceGA.plugin/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/GeForceGA.plugin/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/GeForceVADriver.bundle/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/GeForceVADriver.bundle/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOCDStorageFamily.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOCDStorageFamily.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IODVDStorageFamily.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IODVDStorageFamily.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOHDIXController.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOHDIXController.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOHIDFamily.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOHIDFamily.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOSCSIArchitectureModelFamily.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOSCSIArchitectureModelFamily.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOStorageFamily.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOStorageFamily.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOUSBFamily.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOUSBFamily.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/IOUSBMassStorageClass.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/IOUSBMassStorageClass.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/msdosfs.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/msdosfs.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/ntfs.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/ntfs.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/SMARTLib.plugin/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/SMARTLib.plugin/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/smbfs.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/smbfs.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
kextload: /System/Library/Extensions/udf.kext/sbin/kextload: no such bundle file exists
can’t add kernel extension /System/Library/Extensions/udf.kext/sbin/kextload (file access/permissions) (run kextload on this kext with -t for diagnostic output)
can’t find extension /System/Library/Extensions/System.kext/sbin/kextload in database
kextload: unable to register module with kernel
kextload: a link/load error occured for kernel extension /System/Library/Extensions/smbfs.kext
unlink: /Users/frontrow/Movies/Mac OS X 10.4.9 Combined Update (Intel): No such file or directory
2012-04-02 16:15:59.200 nitoHelper[335] Installation completed successfully
