Judder / lagging / stutter video on iPhone 14 Pro Max
I have been wanting to use Infuse for a long time, but for almost 1.5 years I have been experiencing a kind of lag or judder whenever I play a movie on my iPhone 14 Pro Max.
After some investigation, I noticed this happens specifically with 25fps 1080p H264 content. The HUD confirms it: when judder occurs I see 120Hz / 59.95Hz / 59.95Hz. On content where playback is smooth, the HUD shows 120Hz / 119.90Hz / 119.90Hz.
Summary
Format : Matroska
Format version : Version 4
File size : 4.30 GiB
Duration : 1 h 46 min
Overall bit rate : 5 787 kb/s
Frame rate : 25.000 FPS
Recorded date : 2026-05-24 09:15:21.0972532+02:00
Writing application : Lavf61.7.100
Writing library : Lavf61.7.100
ErrorDetectionType : Per level 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 5 192 kb/s
Nominal bit rate : 6 000 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.100
Stream size : 3.86 GiB (90%)
Writing library : x264 core 157
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=34 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=50 / keyint_min=5 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=cbr / mbtree=0 / bitrate=6000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=6000 / vbv_bufsize=12000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Default : Yes
Forced : No
I have tried to ignore the judder, but it is consistently noticeable. With Swiftfin I do not have this problem and video plays smoothly. The same goes for Streamyfin, as long as the player is set to VLC. When I switch the player to KSPlayer, the same issue appears to occur.
I hope this can be fixed, because Infuse is a great app, but at the moment it is not usable for me.
I have tried setting Streaming Cache to all available options, but the problem persists. Disabling AI Upscaling seems to help slightly at times, but the judder is still there. I have tested on both mobile data and WiFi, all on iPhone only.
