Jog Wheel Problem
Hello, I couldn’t find a suitable entry in the forum. I have the following problem: In every app on Apple TV 4K (3rd Gen), I can use the jog wheel, but not in Infuse. I’m using the latest version (8.0.5). What could be the reason for this?
See if this post and referenced video helps.
Thanks for the fast response.
I’ve already done it as shown in the video. As mentioned, it also works in many other apps (e.g., Crunchyroll). I pause the movie, place my finger on the outer ring (for up to 10 seconds), and… no jog symbol appears.
I don’t use the jog wheel hardly ever so I’m not the best problem solver for this but I did try it and its finicky at best. For me if I pause and then rest a finger on the remote circle with the dots on it for a few seconds it pops up the jog wheel on the time line and I can then use the jog ring on the remote but again, it’s a bit finicky.
For me, it’s not finicky - it’s more like impossible. Out of 20 attempts, it worked once. In other apps, it just works. And as you yourself confirmed, it’s poorly implemented in Infuse. I’d be very grateful if this could be improved.
