Jerk with HDR10 video
The following video can’t be readed properly because of some jerks :
https://we.tl/t-qVzmhoBy9G
No problem with VLC on a PC.
The video is coming from broadcast experimentation in France.
Thx
Which Apple TV model are you using?
Do you have both of the Match Content options enabled in Settings, as described here?
Yes, I have.
Apple TV 4K
Sorry, I solved the problem : my AV receiver is not compatible with HDR10 HLG, because of HDMI 2.0a port (and not 2.0b)
Thanks for your help
Thanks for getting back with what you found!
