I am checking out Jellyfin to use in my network and across my devices.
Now I noticed that when I set something marked as read in my Infuse or in Jellyfin it does not sync to each other. So, when I mark something as read in Infuse, Jellyfin says I have not seen it and vice versa.
Is this normal behavior or not? I have the Infuse plugin installed in Jellyfin.
Tested it again. Set an episode manually as read in Infuse. In Jellyfin it still says it’s unwatched. Even after pushing the sync/reload button manually in Infuse
I run the following:
Infuse 7.4.7 (4279)
Jellyfin server 10.8.5
Infusesync 1.4.2.0
Edit: tested it with infuse on my iPhone. Same issue. Marked as read and unread doesn’t sync to Jellyfin and vice versa.
