Is it normal that the movie list (when you select an actor) ist not synched between my Jellyfin library and the .strmlnk library (folder on my NAS)?
It depends.
If you have Library Mode enabled in Infuse for the Jellyfin share then all items would be linked. But if you have Library Mode disabled (IE using Direct Mode) they would not be linked.
I have library mode enabled for the Jellyfin server, yet when I click on an actor through a .strmlnk movie version, I only see the movies listed that are also from linked versions and not the movies from the Jellyfin server.
I‘m pretty sure this is not working as described. Clicking on an actor from a .strmlnk version only brings up other .strmlnk entries despite there being multiple more (on the Jellyfin server).
