Hello
Thank you for providing native support for Jellyfin media servers.
I have issues when I add new content to my Jellyfin library. Even though it immediately appears on the Jellyfin web interface, when I open Infuse the new content is not there. I can only use it if I manually go to File tab, and choose the Jellyfin media server.
It magically appears in the library a few days later (don’t know the exact time but can check it if that helps). I assume it has something to do with caching and InfuseSync plugin? Same happens to all Infuse apps (iOS, tvOS, macOS alpha)
Information about my configuration:
Infuse: 6.6.1 (and macOS version alpha-10)
Jellyfin: 10.6.4 runing on a Raspberry Pi 4B
InfuseSync: 1.2.4.0
Thanks for the great app.
