You have a bug with new TV series Jean-Claude.Van.Johnson TV show only works properly (Folders(season 1), files, and fetching data) if the file name is without Jean-Claude :), you’ve been lucky this was not Chuck-Norris.Van.Johnson before you fix naming error using -
My episodes are named
Jean.Claude.Van.Johnson.S01E01.1080p WEB-DL.failed.mkv
etc, and all works fine - the parent show folder is actually named Jean-Claude Van Johnson, seems fine.
Infuse doesn’t play well with hyphens or dashes in the file names. This is an know issue and being worked on.
yes this filename doesn’t work. i’m not using dash
Jean.Claude.Van.Johnson.S01E06.1080p.AMZN.WEBRip.DDP5.1.x264-SiGMA
this one works
i hope infuse fix it
This should work in the current version (no dash or dot between Jean and Claude).
JeanClaude.Van.Johnson.S01E06.1080p.AMZN.WEBRip.DDP5.1.x264-SiGMA
It’s something we still hope to improve in an upcoming version.
