I completed the Seas0nPass process on the computer and iTunes says to disconnect the usb and contect to the TV.
I get nothing when I connecti to the TV. The hdmi cable is good. Tested it with another device.
I get nothing on the screen and the light on the ATV2 just does a slow flash.
When I restiore to normal via iTunes and connect to the TV, it works fine.
Any suggestions?
Thank you for your time and attention.
Apple TV2
5.3.1
Seas0nPass version 0.9.3(730) Mac
emmetta.5452:
Any suggestions?
Apple TV2
5.3.1
You have a TETHERED jailbreak, which means you CANNOT remove power after it’s been tethered. If power is removed you have to re-tether it. Tether it next to the TV in which you plan to use it.
