You should throw in the towel with seasonpass. They have not responded to me either as to why seasonpass would update me from 4.4.3 to 5.3 and ruin my atv2.
nm
answer to ankido
how can you state that its anyones fault it clearly says in the JB that it will download the latest IOS for the latest JB for AT2
its at your own risk you should of done your home work simple
how can you complain at this its for free get a grip
answer to ankido
The older version of seas0npass didn’t have that warning, that is the one he used and caused this thread to start.
It was because of ankido that that warning was put in, you should thank him.
dopo la aggiornamento is0 5.3 tutto ok dopo diche spegnendo e riaccendo non parte piu debbo fare ogni volta il boot Tethered come mai ce una risoluzione
after the 5.3 update IS0 okay after Diche off and relight the most part do not I have to do every time the boot Tethered as there ever a resolution
Try to not plug in the power cable. You mac should power your apple tv by itself.
I cannot do this process.
Every time I right click to save the profiles, i get an error saying “SeasOnpass was unable to save the profiles for this Apple TV”.
Is this known? Or am I missing something?
Jailbroke my AppleTV last year to use Firecore, but it was acting funny so I restored it to factory settings a few months back.
Just cut my cable, so I wanted to jailbreak again – only to discover my Firecore license ran out?? So I had to pay again, and re-attempted jailbreaking…
…with no luck. Three hours later, with almost all my hair pulled out, I can’t figure out what to do. I’ve tried everything (yes, including a tethered version of Seas0nPass). Nothing works. About to throw my AppleTV out the window. Help!!
seas0npass may have some bugs, but i got it work finally.
windows 7 pro.
old profile log-in don’t work, it may be some permittion broken windows 7.
create new account, same laptop, run seas0npass on new account just created work fine.
i am able to JB 5.3 with tether off course.
but worked fine, i try switch back to my old log-in same old problem, can not JB.
i hope it will help you.
6.0 jailbreak is worth the wait???
I’m seriously wondering the same thing, though it’s up to pod2g (and friends) to hack the latest OS, then it can be implemented with ATV2.
But odds are, as 5.2.1 and 5.3 are still Tethered(which im amazed about). I’m still on 5.2, wondering why my 3rd party apps wont update??
Am I being forced to 5.3 untethered to receive updates? Or has there been no updates this long on ATV2?
The new updates are pretty sweet for us. HBO Go, and DIsney, Disney JR. So I jumped to 5.3.
If you used ifaith to save your hashes/blobs you can then stich a custom IPSW that you can restore back to. So I comfortably went to 5.3 which it is now too late to do. You’re looking at 6.0 and no JB at this point.
I did a jailbreak to 5.3 a few days ago. As long as Apple are still signing 5.3 (which I believe is the case at the moment) you will still be able to go to the 5.3 jailbroken release despite the fact that 6.0 is what you get if you do a restore in iTunes to a none jailbroken state.
Other device it’s jailbroken iOS 7xx
Bat Apple TV no!!! Progress ?? Jb pls make new jb
With users new fresh Apple TV !
