Jailbreak 4.3 [Problem]
Hello!
I downloaded the New Seas0nPass Tethered Jailbreak for 4.3 (Windows).
Now i tried to Jailbreak my Apple Tv 2:
I started Seas0nPass.exe and it downloaded the New Firmware for Apple Tv 2.
The Install went fine until "Creating IPSW" then when i come to "Compressing.." Seas0nPass Stop there.
I dont get any Error Message or something else, the Loading is come the End and then it stay so.
And nothing happens then.
I am using Windows 7 (x64) and i tried starting Seas0nPass.exe with Admin Rights,
then i tried some other Compat. Mode like Windows XP with Service Pack 1,2 and 3.
But it still wont Install to the End.
What i can do now ?
I need your Help !
Thx!
This is my Log File where the Process Stops:
DateTime: 16.03.2011 08:58:11 Message: Application start
DateTime: 16.03.2011 08:58:11 Message: Seas0nPass 0.3.1.1614
DateTime: 16.03.2011 08:58:11 Message: clean up
DateTime: 16.03.2011 08:58:15 Message: Starting download
DateTime: 16.03.2011 09:09:22 Message: Download completed
DateTime: 16.03.2011 09:09:23 Message: Downloaded file copied to Documents folder
DateTime: 16.03.2011 09:09:24 Message: Patching message changed to: Unzipping...
DateTime: 16.03.2011 09:09:30 Message: Patching message changed to: Decrypting ramdisk...
DateTime: 16.03.2011 09:09:30 Message: Running process: .\bin\xpwntool.exe, args: .\UNZIPPED_ORIGINAL\038-0791-023.dmg ipsw/038-0791-023.dmg
DateTime: 16.03.2011 09:09:34 Message: Patching message changed to: Patching ramdisk...
DateTime: 16.03.2011 09:09:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg ls /usr/sbin
DateTime: 16.03.2011 09:09:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg extract /usr/sbin/asr .\tmp\asr
DateTime: 16.03.2011 09:09:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg mv /usr/sbin/asr /usr/sbin/asr_backup
DateTime: 16.03.2011 09:09:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg grow 25272320
DateTime: 16.03.2011 09:09:34 Message: Running process: .\bin\bspatch.exe, args: .\tmp\asr .\tmp\asr.patched .\8F191m\asr.patch
DateTime: 16.03.2011 09:09:35 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg add .\tmp\asr.patched /usr/sbin/asr
DateTime: 16.03.2011 09:09:35 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg ls /usr/sbin
DateTime: 16.03.2011 09:09:35 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg chmod 755 /usr/sbin/asr
DateTime: 16.03.2011 09:09:35 Message: Patching message changed to: Encrypting ramdisk...
DateTime: 16.03.2011 09:09:35 Message: Running process: .\bin\xpwntool.exe, args: .\tmp\our.dmg .\output\038-0791-023.dmg -t .\UNZIPPED_ORIGINAL\038-0791-023.dmg
DateTime: 16.03.2011 09:09:39 Message: Patching message changed to: Decrypting file system...
DateTime: 16.03.2011 09:09:39 Message: Running process: .\bin\vfdecrypt, args: -i .\UNZIPPED_ORIGINAL\018-7896-152.dmg -k a30f67f64a546a28bfd5c6e2e43d14fd8111c55641fc6dc392891e2b14e7e8138db9344c -o ipsw/018-7896-152.dmg
DateTime: 16.03.2011 09:09:53 Message: Running process: .\bin\dmg-bin.exe, args: extract .\tmp\our-big.dmg .\tmp\our-big-hfsimage.dmg
DateTime: 16.03.2011 09:10:21 Message: Patching message changed to: Patching file system...
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /etc/fstab .\tmp\fstab
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\bspatch.exe, args: .\tmp\fstab .\tmp\fstab.patched .\8F191m\fstab.patch
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /etc
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /etc/fstab etc/fstab_backup
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\fstab.patched /etc/fstab
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /etc/fstab
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /Applications/AppleTV.app/AppleTV .\tmp\AppleTV
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\bspatch.exe, args: .\tmp\AppleTV .\tmp\AppleTV.patched .\8F191m\AppleTV.patch
DateTime: 16.03.2011 09:10:21 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /Applications/AppleTV.app
DateTime: 16.03.2011 09:10:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Applications/AppleTV.app/AppleTV /Applications/AppleTV.app/AppleTV_backup
DateTime: 16.03.2011 09:10:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /Applications/AppleTV.app
DateTime: 16.03.2011 09:10:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\AppleTV.patched /Applications/AppleTV.app/AppleTV
DateTime: 16.03.2011 09:10:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 775 /Applications/AppleTV.app/AppleTV
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /Applications/AppleTV.app
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /System/Library/Lockdown/Services.plist .\tmp\Services.plist
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\bspatch.exe, args: .\tmp\Services.plist .\tmp\Services.plist.patched .\8F191m\Services.patch
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /System/Library/Lockdown
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /System/Library/Lockdown/Services.plist /System/Library/Lockdown/Services.plist_backup
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\Services.plist.patched /System/Library/Lockdown/Services.plist
DateTime: 16.03.2011 09:10:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /System/Library/Lockdown/Services.plist
DateTime: 16.03.2011 09:10:23 Message: Patching message changed to: Installing software...
DateTime: 16.03.2011 09:10:25 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg untar .\tmp\cydia\cydia.tar
DateTime: 16.03.2011 09:13:07 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\asubstrate.deb /private/var/root/Media/Cydia/AutoInstall/asubstrate.deb
DateTime: 16.03.2011 09:13:07 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/asubstrate.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\awkwardtv.deb /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\beigelist.deb /private/var/root/Media/Cydia/AutoInstall/beigelist.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/beigelist.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.gs_0.1-3_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.gs_0.1-3_iphoneos-arm.deb
DateTime: 16.03.2011 09:13:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.gs_0.1-3_iphoneos-arm.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.whatanutbar.exposed._0.5_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/com.whatanutbar.exposed._0.5_iphoneos-arm.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.whatanutbar.exposed._0.5_iphoneos-arm.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\org.xbmc.repo_0.1-1_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\syslogd.deb /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /private/var/root/Media/Cydia/AutoInstall
DateTime: 16.03.2011 09:13:09 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /var/stash
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /usr/include
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /Applications      /var/stash/Applications
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /Library/Ringtones /var/stash/Ringtones
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /Library/Wallpaper /var/stash/Wallpaper
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /usr/bin           /var/stash/bin
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /usr/include       /var/stash/include
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /usr/lib/pam       /var/stash/pam
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /usr/libexec       /var/stash/libexec
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv      /usr/share         /var/stash/share
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Applications      var/stash/Applications
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Ringtones ../var/stash/Ringtones
DateTime: 16.03.2011 09:13:10 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Wallpaper ../var/stash/Wallpaper
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/bin           ../var/stash/bin
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/include       ../var/stash/include
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/lib/pam       ../../var/stash/pam
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/libexec       ../var/stash/libexec
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/share         ../var/stash/share
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Applications
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Ringtones
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Wallpaper
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/bin
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/include
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/lib/pam
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/libexec
DateTime: 16.03.2011 09:13:11 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/share
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\8F191m\uncompress /bin/uncompress
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 755 /bin/uncompress
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /bin
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg ls /private/var/lib/dpkg
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /private/var/lib/dpkg/status .\tmp\status
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\bspatch.exe, args: .\tmp\status .\tmp\status.patched .\8F191m\status.patch
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\status.patched /private/var/lib/dpkg/status.patched
DateTime: 16.03.2011 09:13:12 Message: Patching message changed to: Creating IPSW...
DateTime: 16.03.2011 09:13:12 Message: Running process: .\bin\dmg-bin.exe, args: build .\tmp\our-big-hfsimage.dmg .\output\018-7896-152.dmg
DateTime: 16.03.2011 09:13:49 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu  .\OUTPUT\Firmware\dfu\decrypted.dfu -iv 17742baec33113889e5cbfcaa12fb4f0 -k 998bd521b5b54641fbeb3f73d9959bae126db0bc7e90b7ede7440d3951016010
DateTime: 16.03.2011 09:13:49 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted.dfu .\OUTPUT\Firmware\dfu\patched.dfu .\8F191m\iBSS.k66ap.RELEASE.patch
DateTime: 16.03.2011 09:13:50 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched.dfu .\OUTPUT\Firmware\dfu\encrypted.dfu -iv 17742baec33113889e5cbfcaa12fb4f0 -k 998bd521b5b54641fbeb3f73d9959bae126db0bc7e90b7ede7440d3951016010 -t .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu
DateTime: 16.03.2011 09:13:50 Message: Patching message changed to: Compressing IPSW...
DateTime: 16.03.2011 09:14:37 Message: Saving kernelcache.release.k66 and iBSS.k66ap.RELEASE.dfu files
