When using SeasOnPass, do you need to run through both sides of the applications (Create IPSW , then Boot Teathered)?
When running the Create IPSW side, three times i have tried to jailbreak, and all three times after completing the procedure, the ATV, when plugged back in & hooked up to the TV, shows no video. The light will blnk rapidly for a few second, then go steady, responding to clicks from the remove, but no video output.
Any suggestions?
