After flashing my ATV, i can’t sync to itunes store and buy tv shows/movie/and music.
Why ?
ATV:2.4 aTV Flash: 3.6.3
Why ?
Have you tried logging out and back in?
No,
I try and I wish to current ![]()
I tried logging out and back in, but no change, the problem remains the same. ![]()
Thx
Can´t you reach the store at all? If you can, give us some details about the failure. When does it happen? Are there messages? etc.
cheers
winmann
Hello,
I can sync whith my mac but i can’t buy tv shows/movie/and music directly from my apple TV.
No messages just this one :
http://www.flickr.com/photos/42679125@N07/sets/72157622285056861/
Thx
I’m on french store ![]()
Hi there,
looks like your atv isn´t connected to your iTunes. And because of this it´s probably not activated through iTunes (have not tried buying things prior the activation, so that´s just a guess).
Do you see the atv in iTunes? Have you positively connected it to iTunes? Does it show your Mac under settings/computers?
cheers
winmann
Hi, and thx for your answers ![]()
My ATV is connected and actived and i see the ATV to my iTunes
http://www.flickr.com/photos/42679125@N07/sets/72157622302070257/
On my ATV i see my iMac (sync is ok), and i can stream music, movies, or pictures from my computer to my ATV.
But i can just see the trailers from iTunes Store, not more.
Thx.
The french guy ![]()
After reboot my ATV, everything is ok. I don’t understand but i’m happy. ![]()
Thx for all Winmann.
