Hi:
I have two AppleTV’s and they’re both jailbroken with ATV Flash (black) installed. All is good, very happy. Both are pretty much identical (with one issue that I will soon explain.)
Today I got Apple’s new icon for iTunes Festival: http://www.appleinsider.com/articles/12/08/28/apple_to_stream_live_itunes_festival_shows_via_apple_tv_ios_app.html
On one AppleTV, the icon appears normally.
On the other AppleTV, the icon shows up as a blank (black) square.
Both WORK, mind you, but it’s off-putting that the icon is blank. It looks broken.
The ONLY difference in setup between these two AppleTV’s is that the one with the blank iTunes Festival icon, a few weeks back I had gone into RemoteHD and selected the “Hide Menu Item” command (thinking it would hide the whole icon, not just the version number listed inside.) I did NOT do that on the other. And I quickly realized there’s no way to “Unhide” to undo this mistake. Heck, Maintenance doesn’t even uninstall RemoteHD properly, when I tried that, the icon was removed but Maintenance still says it’s installed.
So, how do I UNHIDE the menu command, or just clear out RemoteHD’s prefs entirely, so I can troubleshoot this?
I don’t use RemoteHD often and would much rather have a proper icon displayed for the new iTunes Festival app.
