Issues with SSH, Maintenance Menu installs etc..
Hi James/All,
IOS 4.4.4, ATV2
The ATV2 appears to be working perfectly, access to media player, stream from my laptop, access to XBMC and all it’s plugins, access to Maintenance Menu
However;
I now cannot SSH into my ATV2, i have tried using both Putty and Cyberduck (windows), Putty gives the error “Server unexpectedly closed network connection” and Cyberduck gives “Connection failed, Premature connection close”
Another issue i found is if i try to install anything from the Maintenance Menu the installation fails on the first attempt when i retry it appears to install correctly.
I have download ATV (Black) 1.6 from the download area and when i run this my ATV2 is found, i get the message “You are using the latest version of aTV Flash (black).” if i click next and choose my ATV2 and click next i get “Installation failied. Oops, it looks like your Apple TV has not yet been jailbroken”
My ATV2 is clearly Jailbroken as XBMC is working perfecty, NAVI-X, Media Player and the Maintenace Menu is visable (working a little strangely though)
Any help, clues or solutions will be great
Thanks in advance
Nic
you can see my response here.
http://forum.firecore.com/topic/8161?page=3#comment-44547
Good luck.
